  3. datatip information
  • State Verified Answer
  • Replies 7
  • Subscribers 162
  • Views 3153
datatip information
masamasa
masamasa 3 months ago
hello
is there a way to show the length of a particular net as the datatip information?
i checked the length value on the datatip customization setting but it shows only the cline length on the current layer.
on the datatip info, i would like to see the total length of a particular net accumulated thru all layers.
regards
masa
  • excellon1
    +1 excellon1 3 months ago in reply to DavidJHutchins
    Hi Masa,
    It is possible to determine the net length by using a data tip, However it only works if the Net is routed. If the net is UN-routed then
    the net length will be zero.
    In the Data Tip for net,  check the following.
    NET - Length, Name & Value "Check both boxes"
    NET - Unroute Connection Count, Name & Value "Check both boxes"
    Click Ok to save that Data Tip.
    In your find filter choose "Net" Hover over a cline that is routed. The data tip should display the net length. I checked this in 16x, 17x
    of Orcad / Allegro. Looks to work fine here
    Best Regards.
  • masamasa
    0 masamasa 3 months ago in reply to excellon1
    thank u everyone.
    it works after i filter only nets.
    regards
    masa
