  3. boundary question
  • State Verified Answer
  • Replies 11
  • Subscribers 166
  • Views 7370
boundary question
masamasa
masamasa over 1 year ago
hello:
i am unable to select a boundary so that i am not unable to delete the boundary.
is there a way to select and remove a boundary?
what prevents me from selecting and removing a boundary?
regards
masa
  • masamasa
    masamasa over 1 year ago +2 verified
    i found a way to remove the boundary by using the skill code named gridded_shape_cleanup.il.
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to JCTEYSSIER0 +1 verified
    Hello JCTEYSSIER0 you can refer this one. ( axlCmdRegister "gridded shape cleanup" ( quote removeFigures) ?cmdType "INTERACTIVE" ) procedure ( removeFigures( ) let ((figures) axlSetFindFilter…
  • excellon1
    0 excellon1 over 1 year ago in reply to masamasa
    Hi Masa,
    Turning on all the layers will make everything visible. If you zoom to the area first it may go easier.
    There is something else to check. It could be some shapes are out of date. Go to "Setup Design Parameters" > Shapes Tab, click
    edit global dynamic shape parameters. On the panel there is a force update button it also shows if any shapes are out of date.
    Maybe see if that helps. If there are out of date shapes run force update to fix that. Then you should be able to select the boundary and delete it.
    Best regards.
  • masamasa
    +1 masamasa over 1 year ago
    • Vote Up +2 Vote Down
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to masamasa
    I am curious: can you share this code?
  • masamasa
    0 masamasa over 1 year ago in reply to JCTEYSSIER0
    this is the skill code that cadence sent to me.
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/gridded_5F00_shape_5F00_cleanup.zip
  • JCTEYSSIER0
    Thank you for sharing.
    Can not read it: it is coded (binary format, not ASCII ) Disappointed
    I was curious about the way it was done. I will do not know Slight smile
