  3. boundary question
  • State Verified Answer
  • Replies 11
  • Subscribers 166
  • Views 7369
boundary question
masamasa
masamasa over 1 year ago
hello:
i am unable to select a boundary so that i am not unable to delete the boundary.
is there a way to select and remove a boundary?
what prevents me from selecting and removing a boundary?
regards
masa
  • masamasa
    masamasa over 1 year ago +2 verified
    i found a way to remove the boundary by using the skill code named gridded_shape_cleanup.il.
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to JCTEYSSIER0 +1 verified
    Hello JCTEYSSIER0 you can refer this one. ( axlCmdRegister "gridded shape cleanup" ( quote removeFigures) ?cmdType "INTERACTIVE" ) procedure ( removeFigures( ) let ((figures) axlSetFindFilter…
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago
    A boundary is a dynamic shape contour definition: if you delete the shape, you will not have boundary anymore since the are linked
  • excellon1
    0 excellon1 over 1 year ago
    Hi Masa,
    The boundary is just an outline of where some object exists on a layer. Typically this will be a shape on some layer. You would need to delete
    the shape associated with the boundary to remove the boundary.
    Click on the icon "Shape Select" to select the boundary, then click the info icon to figure out what layer the boundry is on. Enable that layer so
    as to see the object then delete it. Another method is to turn on all classes/subclasses on so they are visible. GO to Display > Color/Visibility, then
    click the global visibility button "On" to make everything visible.
    Best Regards.
  • masamasa
    0 masamasa over 1 year ago in reply to excellon1
    hello paul:
    unfortunately i am not able to select the boundary by shape select.
    apparently i may have deleted the shape already.
    if i show all layers, i would not know which objects belog to which layer.
    regards
    masa
  • JCTEYSSIER0
    If this is dynamic shape and the area allocated does not permit to have copper this bring to this.
    Just select it as a shape and you will be able to delete it
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to JCTEYSSIER0
    Edit -> Delete
    in find filter, check "Shapes"
    clic on boundary
    Rigth clic -> Done
    No more "boundary"
