  3. SMD pad with opening
  • State Suggested Answer
  • Replies 7
  • Answers 2
  • Subscribers 166
  • Views 5729
bdc66a938f164d
bdc66a938f164d over 1 year ago
I need to create an SMD padstack that has an opening, like this:
When I draw this pad as a shape and try to save it, I get `ERROR(SPMHCS-3): Shape symbol cannot have a void in a shape.`. After a web search it seems to be a limitation of Cadence at the moment, so I tried doing two pads like this:
and then in my footprint incorporating the two pads and give them the same pad number. In this case, however, I get
WARNING(SPMHA1-301): Create symbol DRC errors exist.
Duplicate pin number 1.
WARNING(SPMHA1-298): Create symbol duplicate pin numbers.
ERROR(SPMHA1-291): Create symbol has been aborted.
What is the way to implement this?
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago +2 suggested
    In such case, i will: - use a small round smd pad somwhere in copper area* - add a static shape on "ETCH/TOP" - add static shape on "PACKAGE GEOMTRY/SOLDERMASK"_TOP and "PACKAGE GEOMTRY/PASTEMASK_TOP…
  • Gowtham P
    Gowtham P over 1 year ago +1
    Hi bdc66a938f164d , An SMD pad with a hole is quite interesting! Could you help me understand the purpose or significance of having a hole or void in the pad? Given the current limitations, one workaround…
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago
    - add static shape on "PACKAGE GEOMTRY/SOLDERMASK"_TOP and "PACKAGE GEOMTRY/PASTEMASK_TOP" if required (think so)
    The ETCH shape will automaticaly get the pins's net while placing component: works well for me.
    If netlist modification occure and component already placed, you will probably have to change shape net affectation manually.
    • Vote Up +2 Vote Down
  • excellon1
    0 excellon1 over 1 year ago in reply to JCTEYSSIER0
    Good tip Jc on the extra pin for the shape body of the footprint.
    Best Regards.
