  3. removing objects
  • State Verified Answer
  • Subscribers 166
  • Views 2680
removing objects
masamasa
masamasa over 1 year ago
hello
is there a way to remove all objects including symbols, padstacks, shapes, and clines on a specified layer or layers?
the all objects mean everything that associates with the layer(s) including boundaries
sometimes it takes hours to remove all objects manually only on a single layer.
regards
masa
  • masamasa
    masamasa over 1 year ago +1 verified
    hello hoangkhoi gave me a skill code offline that solves this issue. thank u, hoangkhoi regards masa
  • masamasa
    +1 masamasa over 1 year ago
    hello
    thank u, hoangkhoi
    regards
    masa
  • Elecguy
    0 Elecguy over 1 year ago in reply to masamasa
    Can we get permission from the author to publish this solution? I've always done this process manually
  • masamasa
    0 masamasa over 1 year ago in reply to Elecguy
    hello elecguy:
    i do not think the author would like to disclose the code as i received an encrypted skill code with a password.
    i can not even look at the code inside, either.
    when uploading the code, i need to enter the password.
    regards
    masa
