  3. Netlist import error - possibly related to sync
  • Views 1148
FilipSwe
FilipSwe over 1 year ago
I get this error message when importing a netlist to my design. I assume it is because constraints sync or something similar has been turned on. I do not use the sync function normally, I prefer to import/export netlist manually.
How do I get rid of it?
Filip
  • Elecguy
    0 Elecguy over 1 year ago
    You're right that the constraint sync is causing it. Have you tried turning it off? do you still get it?
  • FilipSwe
    0 FilipSwe over 1 year ago in reply to Elecguy
    Ok thanks. Do you know how to turn off the sync? I have not been able to find the right setting.
