  3. Broadside coupled differential pair, possible in Allegro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 2737
Broadside coupled differential pair, possible in Allegro?
bdc66a938f164d
bdc66a938f164d over 1 year ago
I am interested in routing differential pairs in a broadside coupled configuration, see [here](https://www.allaboutcircuits.com/tools/broadside-coupled-stripline-impedance-calculator/). Is this possible with Allegro?
  • steve
    steve over 1 year ago +1 suggested
    Yes but you have to start and finish the route in single trace mode. Start routing the diff pair then right click - Single trace mode and route one to a start point on one layer, Repeat for the other half…
  • steve
    0 steve over 1 year ago
    Yes but you have to start and finish the route in single trace mode. Start routing the diff pair then right click - Single trace mode and route one to a start point on one layer, Repeat for the other half until they are coicident, then change the mode to not use Single Trace mode and they will route together, repeat for the other end. It doesn't to report any DRC's for uncoupled length and phase on my example but that may depend on the stackup thickness and rule values defined.
  • Robert Finley
    0 Robert Finley over 1 year ago in reply to steve
    this might help:
     Broad side coupled differential pair
  • bdc66a938f164d
    0 bdc66a938f164d over 1 year ago in reply to steve
    Thanks, this worked.
