  3. Variable trace width during serpentine routing for PCIe...
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 166
  • Views 5405
Variable trace width during serpentine routing for PCIe 5.0 (PCB Editor 23.1)
bengelJF
bengelJF over 1 year ago
Our electrical team was discussing the recommendation below from Texas Instrument's app note "High-Speed Layout for PCIe Gen 5":
It's easy enough to change the width of a given cline segment by hand, but ideally this would happen automatically during delay tuning so we don't have to do this by hand (takes more time, easy to miss a segment). Additionally, we run into the "snowman problem" when just changing trace widths, where the larger segment doesn't blend nicely into the smaller segment:
So, our question is this: In PCB Editor 23.1, is it possible to set up trace widths to adjust automatically to match TI's suggestion in their app note, and if so, is it further possible to get nice blended transitions from thinner to wider segments?
Thanks all!
  • DavidJHutchins
    DavidJHutchins over 1 year ago +2 suggested
    I developed some skill code for this issue years ago, the solution for the 'snowman' issue was to split the 45' segment as the location of the width change, as show below:
  • masamasa
    masamasa over 1 year ago in reply to DavidJHutchins +1
    hello david i have never worked on pcie but it looks like u can just add a taper at the width change to avoid the snowman issue. regards masa
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to masamasa +1
    Hello Masa, the trace width difference between the inner pair & outer pair is not as large as you showed The Signal Integrity engineers at HP & Intel were happy with my solution...
  • avant
    0 avant over 1 year ago in reply to DavidJHutchins
    Thanks, that's what I thought.
    They should rewrite or delete those two sentences. It made me question basic impedance practices.
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    hello david:
    i see the guideline saying ">3xW."
    so it can be 10xW if u have enough space.
    i think my design does not violate the guideline.
    maybe i do not know much about pcie.
    regards
    masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to masamasa
    Masa,
    I was told that you need to change the width on both segments in the section where the distance is larger,
    in the image you can see both are changed...
