  3. loading skill codes
  • State Verified Answer
  • Subscribers 166
  • Views 3787
loading skill codes
masamasa
masamasa over 1 year ago
hello
is there a way to automatically load all skill codes from the skill folder when opening a design file?
typing skill load("XXXX.il") in the command line is somewhat annoying.
regards
masa
  • steve
    steve over 1 year ago +1 verified
    Yes - you can use an allegro.ilinit file. Go to the Parallel Systems Website then User Guides (bottom of the webpage) and look at PCB1 which covers this.
  • excellon1
    excellon1 over 1 year ago +1 verified
    Hi Masa, In addition to what Steve mentioned. Here is what I use. Might be helpful. In your pcbenv folder you need a file called allegro.ilinit. This file gets loaded when Allegro starts up. The…
  • DE202408202727
    DE202408202727 over 1 year ago +1 verified
    If you only want to load code as it is needed, use the autoload feature: xxxx.autoload = "yyyy.il" Where xxxx is the name of your function. yyyy.il is the name of the Skill file containing the function…
  • steve
    +1 steve over 1 year ago
  • excellon1
    +1 excellon1 over 1 year ago
    Hi Masa,
    The file is basically a text file. Inside this file I have the following.
    setSkillPath(buildString(append1(getSkillPath() "C:/Allegro-Skill-Files" )))
      foreach(dir getSkillPath()
        when(isDir(dir)
               foreach(file rexMatchList("\\.il$" getDirFiles(dir))
            when(
               printf("Loading Skill file: %s\n" file)
               load(file)
    My skill folder path is C:/Allegro-Skill-Files, you could change that path to suit your needs.
    Best regards
  • DE202408202727
    +1 DE202408202727 over 1 year ago
    Where xxxx is the name of your function. yyyy.il is the name of the Skill file containing the function.
    I put my axlCmdRegister commands in the same place. eg:
    axlCmdRegister("pmchk", 'pasteMissingChk, ?cmdType "general")
    pasteMissingChk.autoload = "pasteMissingChk.il"
