  3. Extension of env-file
  • State Suggested Answer
  • Answers 1
  • Views 1924
JuriVi
JuriVi over 1 year ago
Hello everybody,
as I know the Orcad X PCB Designer needs to use the env-file WITHOUT any extensions. I also tested with env.txt and env.env and it doesn't work.
Without an extension the env file can't ALWAYS be opened with an App (e.g. Notepad) in Windows 11.
My question is: is there any extension that will be accepted by OrCAD X PCB Designer?
JuriVi
  • JuanCR
    0 JuanCR over 1 year ago
    Hi JuriVi
    The file does not have an extension, like you said. However, it should always be possible to open with apps like Notepad. Maybe it doesn't automatically open, but Windows will offer a list of applications to choose from and Notepad is usually there.
