  3. Fonts used for Reference Designators, Pin numbers etc?
  • Views 2264
Ulf K
Ulf K 10 months ago
1.
I am trying to figure out which font (The default one) that is used for Reference Designators, Pin numberings, etc since I also
wanted to use this for silk screen (Board Geometry) like Board name, revision information and misc. other texts.
This font seems to be unavailable in the new font selection canvas. Arial, Comic Sans, Courier, etc can be selected
but there seems to be no entry for "Cadence Default".
2.
One wish would be that Cadence introduced some sort of "Font Compiler" that would enable a user to add any type of true-type font into the
font selection canvas. I have previously looked for "Andale Mono" (or Andale dot) since that font distinguishes between
the digit zero (0) and the capital letter O and the Danish Ø  (= OE) that is sometimes also used in hex codes for digit 0
by using a 0 with a dot centered inside it.
  • oldmouldy
    0 oldmouldy 10 months ago
    The "default" font is driven by Text Blocks and is not a True Type font since these weren't supported before 25.1 To see the "default" font, enable Text Blocks in Setup>User Preferences, UI, Control Panel. Options are Font Styles, the default and True Type fonts only, Text Blocks, for the "default" font only, or Both, to support both in Options (Style) when adding Text.
    I would have expected "any" True Type font added to the Windows Fonts to be supported and available as a Font Style to select. No idea how that might work with Linux.
