  3. Productivity Toolbox - Post Processing - ODB++ Generati...
  • State Verified Answer
  • Views 2028
Productivity Toolbox - Post Processing - ODB++ Generation
ersgfserg645
ersgfserg645 10 months ago
I can export ODB++ from Allegro PCB Editor 25.1.
I would like to add ODB++ generation to the Post Processing output generation job, so that it is generated as part of the default output data.
How to achieve this?
Like this (timestamp 1:55, creating an ODB++ task and including a .scr file):
https://www.youtube.com/watch?v=8-p4AfQ9apU
I can do that, but what is in the .scr file?
  • steve
    steve 10 months ago +1 verified
    Before you go to the effort of doing this take a look at Manufacture - Export to Manufacturing. This is a new command ( I think) in 25.1 Allegro and allows you to create a list of all the output files…
  • steve
    +1 steve 10 months ago
    Before you go to the effort of doing this take a look at Manufacture - Export to Manufacturing. This is a new command ( I think) in 25.1 Allegro and allows you to create a list of all the output files you want to generate. You can include gerber, ODB++, IPC2581, NC Drill, PDF's etc. When you run this all the files are generated and placed in a zip file.
  • ersgfserg645
    0 ersgfserg645 10 months ago in reply to steve
    Thanks for pointing that out.
    It may not be the answer to the original question, but it makes the question obsolete from my side
    - I think that I will try and go with the Manufacture - Export to Manufacturing approach as it seems to be able to do what I want.
    You are right, that menu item is not there in 23.1 at least.
    Amazing that the transition from 23.1 to 25.1 apparently brings not only 1 but 2 new ways of doing the same thing.
