  3. How to unlock symbol?
  • State Verified Answer
  • Views 2184
bdc66a938f164d
bdc66a938f164d 9 months ago
I have a symbol that somehow got locked and cannot be moved. I do right click, property edit, look for "Locked" and cannot change its value as shown below:
If I select the option without value and hit "apply" then Allegro says "Property `LOCKED` requires a value`. If I try to delete that property by checking the box and hitting apply, Allegro says:
(SPMHA1-147): No such child. Contact Cadence Customer Support with the design file and the steps resulting in the error.
(SPMHGE-248): No instances of property LOCKED found on the selected element(s).
How can I unlock the symbol?
  • bdc66a938f164d
    bdc66a938f164d 9 months ago +1 verified
    For anyone having the same issue: The problem is that the components had been grouped into a module. To be able to edit the module, change the "Find" setting to "Groups".
  • bdc66a938f164d
    +1 bdc66a938f164d 9 months ago
