  3. Net Logic
  • State Verified Answer
  • Replies 14
  • Answers 1
  • Subscribers 169
  • Views 8378
Net Logic
Wildwpe
Wildwpe 9 months ago
Had a really fun task I've been working and I am at the last step.
We had Gerbers from over 20 yrs ago and of course no board or schematic file, so I had to recreate the layout from the Gerber files.  I used DXF imports and the logic commands and have finished the work.  We did output artwork compares using a Gerber tool to confirm accuracies.
So here's my question:
I created 6 nets that have no logic assigned to them, and I can't seem to delete them form the database.  I am able to rename them, and confirm they are unassigned. Tried every trick I could think of.  Any suggestions? (please no skill code).
Wild
  • ltoohey
    ltoohey 9 months ago +2 verified
    export 3rd party netlist, remove the nets, re-import the netlist
  • Wildwpe
    Wildwpe 9 months ago in reply to Wildwpe +1
  • B Bruekers
    B Bruekers 9 months ago in reply to Wildwpe +1
    why no skill code? Just one line you can copy/paste into your normal command window. You only need to change the netnames to-be-deleted. (need to be all uppercase) skill axlDeleteObject(setof(netid…
  • Hoangkhoipcb
    0 Hoangkhoipcb 9 months ago in reply to B Bruekers
    Hi B Bruekers
    I’d like to add a few more points.
    skill axlDeleteObject(setof(netid axlDBGetDesign()->nets netid->branches == nil && member(netid->name list("NET1" "NET2" "NET3" "NET4" "NET5" "NET6"))))
    BR
    HoangKhoi.
  • JCTEYSSIER0
    0 JCTEYSSIER0 9 months ago in reply to Wildwpe
    Be aware "space" in directories and files . Sometimes it because they may be interpreted as field separator.
    I never use space ( ) but use underscore (_) instead
  • Wildwpe
    0 Wildwpe 9 months ago in reply to B Bruekers
    I'm an old dog, no new tricks...
    Been doing Allegro almost 25 years...
  • Wildwpe
    0 Wildwpe 9 months ago in reply to ltoohey
    I was able to figure it out.  The export did not include the unused net.  Was not able to import the netlist, had some type of error.
    However when I created the IPC356 file, these nets were not included, so no issue.
    Thanks for the recommendation.  I consider this case closed.
  • avant
    0 avant 9 months ago in reply to Wildwpe
    For future reference, you need to export the library files from Allegro.
    The netlist import needs to see symbol files, pads, and device files.
    On the Export Logic/Netlist tab, select "Other" to generate a flat ascii netlist. This netlist can be edited.
