  3. Library not existing when downloading external symbols
  • Views 1680
jritter
jritter 9 months ago
Hi all,
after a short pause of designing PCBs I wanted to do a schematic,
now I try to import a Symbol/Footprint from any external source with the help of the integrated Component Explorer and its plugin to Samacsys and Ultra Librarian.
For both the following error occurs neglecting which component I want to integrate.
ERROR(ORCAP-2472): Failed to place symbol instance for model 'AD7314ARMZ' because library '' does not exist.
Even the try to include a new library does give a solution. After upgrading to 25.1 it is not working either.
After modifying the capture.ini to
[Part Selector Configured Libraries]
Dir0=C:\Users\julian ritter\Documents\Cadence_Workspace\LIBRARY1.olb
Number of Configured Libraries=1
the same error occurs.
Is there any solution for this problem?
  • JCTEYSSIER0
    0 JCTEYSSIER0 9 months ago
    Hello Julian,
    i do not know if this is the root problem but it is not a good idea to have special characters in pathname and filename.
    And space is a special character: it is considered by some tools as a field separator.
    My recommendation is to use only letters (a to z or A to Z), numbers (0 to 9),dash (-) and underscore (_).
