  3. SPMHGE-268 netin had erros, use Viewlog to review the log...
  • Views 1646
SPMHGE-268 netin had erros, use Viewlog to review the log file
hnguyen2310
hnguyen2310 8 months ago
I have a brd file that I want to add some decoupling caps in a "quick and dirty" way, just so I can run some simulation quickly. I put these additional caps in a netlist (.txt file) and make sure the formatting is correct. I push this netlist in the board using 'import --> logic/netlist --> Other'. I get the above error "SPMHGE-268 netin had erros, use Viewlog to review the log file"
A collegue of mine tried importing this same .txt and was successful. So it was not because of the txt file. Has anyone run into this issue before? Thanks.
  • Hoangkhoipcb
    0 Hoangkhoipcb 8 months ago
    Hi hnguyen2310,
    Could you please show me the "netin.log" file?
    BR,
    HoangKhoi
  • avant
    0 avant 8 months ago
    When importing an ascii netlist, the .psm, .pad, and .txt (device files) must be in a path that Allegro can see it.
