  3. Unable to generate ODB++ for a particular board
  • State Suggested Answer
  • Answers 3
  • Views 2612
Shashank
Shashank 8 months ago
While trying to generate ODB++ for the board below error pops up, it happens only for this particular board.
Kindly let me know what could be the issue here
'C:/test-/log_brd2odb.log' does not exist.
  • SaiPavanl
    SaiPavanl 8 months ago +1 suggested
    Hello Shashank , Can you let me know the ODB++ inside version are you using Check if the below environment variables are set in the System Environment variables: ALLEGRO_BRD2ODB = C:\SiemensEDA\ODB+…
  • SaiPavanl
    SaiPavanl 8 months ago in reply to Shashank +1 suggested
    Please check whether the TMP folder has write permissions. Also, change the design file location to a new folder and then try exporting the ODB++ again
  • SaiPavanl
    0 SaiPavanl 8 months ago
    Hello Shashank, Can you let me know the ODB++ inside version are you using
    ALLEGRO_BRD2ODB = C:\SiemensEDA\ODB++_Inside_Cadence_Allegro\brd2odb_2504
    BRD2ODB_TMP = Any writable directory
  • Shashank
    0 Shashank 8 months ago in reply to SaiPavanl
    Hi SaiPavanl ,
    The version i am using is V2403.
    The variable is also set in system environment variables.
  • SaiPavanl
    0 SaiPavanl 8 months ago in reply to Shashank
  • Shashank
    0 Shashank 7 months ago in reply to SaiPavanl
    Thankyou, i will try this once
  • JCTEYSSIER0
    0 JCTEYSSIER0 7 months ago in reply to SaiPavanl
    I will add some instructions about full pathname (full pathname is directory path plus filename):
    - Do NOT use special and space characters. Use ONLY letters, numbers , underscore and dash.
    - Use a short fullpathname: verry long pathname can prevent tool (and operating sytem) working properly
