  3. Autoplace - how to use it
  • State Suggested Answer
  • Answers 1
  • Subscribers 167
  • Views 2326
DH202512105348
DH202512105348 7 months ago
I have never used autoplace, but am now trying to use it, in part to compare its capabilities to those of other tools out there.  I have not been able to successfully get it to run.  I set things up, adding place keepings, and place-grids, but there is always an error (usually about a lack of place grids, no matter how I add them, or how many I have added).  I have found posts dating back to the mid 2000's about this issue, but none with any solutions.  I have not found any evidence of anyone ever successfully using this feature.  If you have successfully used it, do you have any suggestions?  Does anyone know of any sort of tutorial with a detailed description of the steps involved?
Dave
  • excellon1
    excellon1 7 months ago in reply to DH202601057529 +2 suggested
    Yes indeed, I was going to suggest that too. The Placement tool in Specctra has a useful graphical feature called Force-Vectors in that it can show visual proximity needed between components and pins.…
  • Robert Finley
    Robert Finley 7 months ago +1
    Check Youtube for an overview of a plugin called CircuitSpace from EMA-EDA. For Orcad users, it's called PCB Clustering. Highly recommended. Layer mapping to dissimilar stackup/layer counts and opposite…
  • DH202601057529
    DH202601057529 7 months ago in reply to Robert Finley +1
    Something that 99% of the Allegro users are not aware of is that the 'route editor' (i.e. specctra ) has a placement mode that is IMHO way better than the Allegro autoplace functionality
  • techiecs
    0 techiecs 7 months ago
    The layout editor requires that you create a placement grid for the area where you run any mode of automatic placement. Automatic placement places packages only at the intersections of the placement grid lines. I believe the due to this you must be getting some lack of place grids error that you're mentioning here.
    Below link covers this in detail-
    support.cadence.com/.../techpubDocViewerPage
    Can you please share the exact error message that you're getting while using Autoplace option or a snapshot of it.
    Also, while using Place> Autoplace, which is the mode you're using to run automatic placement here.
    I hope this is the option you're using to autoplace in allegro, else please do let me know if you're using something else which I may have misunderstood here.
  • DH202512105348
    0 DH202512105348 7 months ago in reply to techiecs
    Thanks!
    I am trying the "design" option first, as that seems like the least complicated.  Thanks for the link.  Their documentation doesn't really seem to get into the specifics of things like the place grid, which seem important for making the thing work.  I have a top and bottom package keeping shape that takes up the whole board, and I then make "Top Grids" and "Bottom Grids" settings and click on the keeping areas (top and bottom respectively) and it seem to make the grid.  I have tried many different sizes.  It sure seems like there is a placement grid.  Here is the error I get (I have also tried placing all the components first, but that doesn't work either):
    Algorithm : IC
    Place within: board
    Map grid points to: library origin
    Place leftovers on bottom: YES
    Allow component overlap: NO
    Soft boundary: NO
    Cluster: YES
    No Rat: NO
    Remove TAG: NO
    Components at rotation of 0 degrees are weighted 50
    Components at rotation of 90 degrees are weighted 0
    Components at rotation of 180 degrees are weighted 0
    Components at rotation of 270 degrees are weighted 0
    Board direction of north is weighted 50
    Board direction of east is weighted 50
    Board direction of south is weighted 50
    Board direction of west is weighted 50
    Component mirroring weight is 50
    Component straightness weight is 50
    Warning: unplaced components are not PLACE TAGGED.
    Placement Keepin
    line seg (700.00,16700.00) (700.00,500.00)
    line seg (700.00,500.00) (20100.00,500.00)
    line seg (20100.00,500.00) (20100.00,16700.00)
    line seg (20100.00,16700.00) (700.00,16700.00)
    Error: No Placement Grid was found
    Error: See message(s) above
  • DH202512105348
    0 DH202512105348 7 months ago in reply to DH202512105348
    I found the problem.  Hitting "done" after setting up the placement grids breaks the whole process.  If I go through with the rest of the placement without hitting "done" after setting up the grids, it sometimes works (about 50% of the time it just crashes instead).
    Thanks again for the info.  I wish Cadence would provide more specific documentation about this sort of thing that doesn't skip many important steps (how to "tag" the components for placement, for example, and the importance of not selecting done at the end of setting up the grids).
  • Robert Finley
    0 Robert Finley 7 months ago
    Highly recommended.   Layer mapping to dissimilar stackup/layer counts and opposite sides.
    Can't imagine using Allegro without it.
  • DH202601057529
    0 DH202601057529 7 months ago in reply to Robert Finley
