  3. How to adjust font size and weight in "show element" pop...
  • State Verified Answer
  • Views 1010
How to adjust font size and weight in "show element" pop-up window?
avant
avant 7 months ago
The csetting under setup/UI/font only controls the menu font.
  • avant
    avant 7 months ago +1 verified
    OK, Under UI setup / font, I set "fontfixedface" as 'arial bold'. I can see the information clearly now.
  • Elecguy
    0 Elecguy 7 months ago
    You can always use Ctrl + mouse wheel ... Although it'll revert to its original size of you end the command.
  • avant
    +1 avant 7 months ago
    OK,
