  3. Accessing user defined Properties in Documentation Editor...
  • State Verified Answer
  • Subscribers 166
  • Views 1556
Accessing user defined Properties in Documentation Editor Templates
Electro Node
Electro Node 6 months ago
Hello All,
I have created some user‑defined properties on components in PCB Editor. While generating APP data using the Documentation Editor, I can see all the standard component properties in the template, but the user‑defined properties do not appear.
Is there a specific setup, configuration, or property‑mapping step required to make user‑defined component properties available in the Documentation Editor templates in assembly documents?
Best Regards,
  • LogicNet
    LogicNet 6 months ago +1 verified
    Hi Electro Node , Documentation Editor only shows what comes through the IPC‑2581 export from PCB Editor. Standard properties are included by default, but user‑defined component properties are not unless…
  • Elecguy
    0 Elecguy 6 months ago
    How are you adding these properties?
  • Electro Node
    0 Electro Node 6 months ago in reply to Elecguy
    Some of the properties are being added at the schematic level, and for a few components, I have added them in Allegro itself.
  • LogicNet
    +1 LogicNet 6 months ago
    Hi Electro Node ,
    Documentation Editor only shows what comes through the IPC‑2581 export from PCB Editor. Standard properties are included by default, but user‑defined component properties are not unless you explicitly add them to the IPC‑2581 export setup.
    If IPC‑2581 export properties have already been defined, new custom properties won’t be picked up automatically. You need to go to File > Export > IPC2581, add the required component property under the Export Property tab, and then reopen/refresh Documentation Editor.
    Once the property is part of the IPC‑2581 export, it will appear in Documentation Editor templates (like Parts List).
  • CJ202604307615
    0 CJ202604307615 6 months ago
    This usually happens when user-defined properties aren’t mapped or exposed to the documentation layer. Try checking if those properties are marked for export or included in the template configuration. Also, verify naming consistency and scope, sometimes only specific property sets are picked up by default.
  • Electro Node
    0 Electro Node 6 months ago in reply to CJ202604307615
    Hi CJ202604307615,
    Thanks for the suggestion and your input on this.
    I have checked, and the solution suggested by LogicNet LogicNet works well here. I believe the documentation editor considers the properties from IPC-2581. The properties defined while exporting IPC-2581 are taken into account by the documentation editor.
    Although the properties are visible in Allegro and work fine, they are not reflected unless we add those properties to IPC-2581 export. So, I tried the suggested solution, and it worked for meSlight smile.
