  3. why does export> NCroute> fail to export a rte file with...
  • State Suggested Answer
  • Answers 3
  • Views 1877
why does export> NCroute> fail to export a rte file with the tool size defined?
RFinley
RFinley 6 months ago
I can't convince finance/operations to stop using ODMs that prefer fabricators who can't import ODB or IPC-2581
Thanks.
I  get "WARNING(SPMHMF-326): Cannot find NC Route bit tool file 'ncroutebits.txt'
 WARNING(SPMHMF-327): ... will auto-generate bit tool file 'ncroutebits_auto.txt'.
 Auto-generating tool file 'ncroutebits_auto.txt'
...every time.
log:
Processing NC Parameters file 'nc_param.txt' ...
 NC PARAMETERS
 FORMAT   		2.5
 MACHINE-OFFSET		x:0.00000	y:0.00000   (mm)
 FEEDRATE		1
 COORDINATES		ABSOLUTE
 OUTPUT-UNITS		METRIC
 TOOL-ORDER		INCREASING
 REPEAT-CODES		YES
 SUPPRESS-LEAD-ZEROES	NO
 SUPPRESS-TRAIL-ZEROES	NO
 SUPPRESS-EQUAL		NO
 TOOL-SELECT		NO
 HEADER			none
 LEADER			12
 CODE			ASCII
 SEPARATE		NO
 SEPARATE-ROUTING	NO
 OPTIMIZE_DRILLING	NO
 ENHANCED_EXCELLON	NO
 SCALE			1.000000
 Auto-generating tool file 'ncroutebits_auto.txt' ...
     0.6000  T01
Pre_processing route path data ...
 WARNING(SPMHMF-296): No route path data was found for processing.
 Processing slot hole data ... TOP to BOTTOM
 OVAL      slots routed: 14
 RECTANGLE slots routed: 0
 NC Route file 'Y.rou' created ...
 Program completed.
  • RFinley
    0 RFinley 6 months ago
    By the year 2026, I would hope Excellon file generation wouldn't be producing random results.
    When it does work, this is the route file header I need.   CAM350 needs it to set the correct route toolsize and show artwork correctly:
    M48
    METRIC
    T01C.6
    I'll admit that going into  SETUP> User Preferences Editor> >Paths >Config >ncpath  and adding my pcbenv path solved a few problems.
    But..
    0.6000 T01
    After about 15 iterations, it always says it can't find then made a new routebits file.  But, it's stopped including those lines in the .rou.
    CAM350 guesses and sets it to 2.31mm, which is bad.  No idea where that's coming from.
  • excellon1
    0 excellon1 6 months ago in reply to RFinley
    It works fine, but there is a bug in cam350.
    Your parameter file for the drills and routes need : the following checked.
    Automatically create drill ncroutebits_auto
    Leading Zero Suppression
    Enhanced Excellon Format  "Should be using this for everything" <<<<<<<<<<<
    The default file produced for the routing is a .rou file for nc-routes
    When creating the actual drill file check these.
    Auto Tool Select
    Separate files for plated non plated holes
    Optimize drill head travel
    Best regards.
  • excellon1
    I responded to your question. Flagged as Spam LOL. Wow most sad. Trying again.
    Check The following in your NC Parameters Setup.
    Automatically create drill_ncroutebit_auto
    Auto create drill ncroutes
    Wnen creating your drill file use.
    Auto Tool select
    Seperate Files for plated Non plated holes
    When creating the Routes file Check.
    Seperate Files for plated non plated routing
    Best regards.
  • RFinley
    0 RFinley 6 months ago in reply to excellon1
    ugh.  Needs work on documentation.
    Arguably, the issue starts with:   why the toolsize isn't exported by default?
    Not useful without the toolsize.
    Thanks!  Need to work on this so my coworkers are successful.
  • excellon1
    No, Your issue here on the NC routes is you are not using "Enhanced Excellon Format" in your parameters file !
    The NC Route file creates std g-code which is a profile of the routing to be performed, the width of your slot is typically the tool size, however at the board house for routing they may use one of their STD router bits instead. As long as the physical routing bit is smaller than your slot it can route out the board. The important thing here is the profile information.
    If you use Enhanced Excellon Format" The tool will be listed in the file. Here is an example at the start of the routing file using enhanced EX format.
    M48
    INCH,TZ
    T01C.056
    ;EXTENTS: -6.800  -7.000  21.200  10.000
    ;LEADER: 12
    ;HEADER:
    ;CODE  : ASCII
    Here is an example of not using the enhanced excellon format. No tool shows up.
    ;LEADER: 12
    ;HEADER:
    ;CODE  : ASCII
    Best Regards.
