  3. How to use skill to select Domain for each film in Allegro...
  • State Verified Answer
  • Subscribers 166
  • Views 1081
How to use skill to select Domain for each film in Allegro X
MZ20250602835
MZ20250602835 5 months ago
Dear All,
may i ask how could i select Domains such as Artwork, IPC2581, PDF or Visibility for each Film using skill? Many thanks.
Many thanks and Best Regards
  • JuanCR
    JuanCR 5 months ago +1 verified
    Hi MZ20250602835 When you create a film using the verb axlFilmCreate you can specify the domain. Look at the syntax description and pay attention to what I'm highligting in bold: axlFilmCreate…
  • JuanCR
    +1 JuanCR 5 months ago
    Hi MZ20250602835
    axlFilmCreate(
    t_filmname
    ?negative               t/nil
    ?undefineLineWidth      f_width
    ?sequence               x_number
    ?rotation               x_angle
    ?xOffset                f_x
    ?yOffset                f_y
    ?shapeBoundingBox       f_value
    ?mirrored               t/nil
    ?fullContact            t/nil
    ?suppressUnconnectPads  t/nil
    ?drawMissingPadApertures t/nil
    ?useApertureRotation    t/nil
    ?suppressShapeFill      t/nil
    ?vectorBasedPad         t/nil
    ?drawHolesOnly          t/nil
    ?layers                 lt_layers
    ?domains                lt_domains
    ?ipc2581                lt_ipcDomains
    ) -> t/nil
  • MZ20250602835
    0 MZ20250602835 5 months ago in reply to JuanCR
    Dear JuanCR,
    many thanks again this is what i need especially ?domains lt_domains
    I created the skill with your help and it works as i expect. Many thanks again for your help and support.
    Best Regards
    Moyan
  • HR20260624375
    0 HR20260624375 4 months ago in reply to JuanCR
    thanks
