  3. How to avoid such same shape spacing problem
  • Views 101
JCTEYSSIER0
JCTEYSSIER0 5 days ago
I regurarly have shapes problem feedback from pcb manufacturers.
Let me explain with an exemple: we have 0.1mm air gap here but my setup is:
min width 0.12
min spacing 0.12
Spacing between via pad and cline is only 0.347mm so i agree shape can not be drawn here (need 3*0.12 mm = 0.36mm to be possible)
The problem is 0.1mm between same shape.
I do not find any setup to avoid this. Nor to dectec it.
How can i get a DRC here: should be one since 0.1mm is less that 0.12mm
Jean-Charles
