  3. How do I cut only a cline segment ?
  • State Suggested Answer
  • Answers 1
  • Views 1006
BC202603263145
BC202603263145 4 months ago
While working on routing, I often need to adjust or remove just a specific section of a trace. However, the tool seems to treat the entire trace as a single entity or trace segments forcing me to rework the whole trace even when changes are required only on specific length.
Is there a method to isolate and cut only a portion of cline segments?
  • JuanCR
    JuanCR 4 months ago +1 suggested
    Yes, there is a way. For both the Slide and Delete commands, you can right-click the cline segment that you want to edit and select the option "Cut" (example with slide): Once you select "Cut…
  • JuanCR
    0 JuanCR 4 months ago
    Once you select "Cut", you'll have to choose 2 points in the cline and the tool will separate the portion of the cline segment in between the chosen points and apply your command to it.
    In the above example, once I select and cut a portion of the segment, it would look like this:
    If it was the delete command (instead of the slide), the section between the chosen points would disappear as soon as you confirm.
  • Hoangkhoipcb
    0 Hoangkhoipcb 4 months ago in reply to JuanCR
    Thanks JuanCR
  • BC202603263145
    0 BC202603263145 4 months ago
    Thanks! JuanCR
