  3. SPB 16.6 BASE RELEASE NOT FOUND
  • State Suggested Answer
  • Answers 1
  • Views 723
KB202607102640
KB202607102640 4 months ago
Hello everyone,
I have a legitimate Cadence OrCAD/SPB 16.6 standalone perpetual license purchased directly from Cadence.
However, the installation DVD I have contains only:
  • HotFix_SPB16.60.010_wint_1of1.exe (ISR10)
  • My license (.lic) file
  • The installation guide (PDF)
There is no SPB/OrCAD 16.6 Base Release installer (setup.exe, Disk1, Disk2, etc.).
When I run the HotFix installer, I receive the following error:
SPB 16.6 Base Release Not Found
I understand that the HotFix requires the Base Release to already be installed, but I do not have the Base Release installation media.
My questions are:
  1. Is the SPB/OrCAD 16.6 Base Release still available for customers with a standalone perpetual license?
  2. Can it still be downloaded from the Cadence Support Portal?
  3. If not, what is the recommended way to obtain the Base Release installer?
  4. Has anyone else encountered this situation where only the ISR DVD was provided?
I would appreciate any guidance from Cadence staff or users who have dealt with this issue.
Thank you.
  • John T
    0 John T 4 months ago
    Hi KB, my name is John from the Cadence support team. The old tools are not technically supported and designed for 32bit OS. The best way to get this is to open a case with us so we can work with you on this. I have sent you a community friend request so we can discuss further and I will do my best for you.
  • John T
    0 John T 4 months ago in reply to John T
    Hi KB - I have no reply from you yet... i see you posted the same question twice on the community it seems Hope you can find this friend request. You should have received a personal email about the request also to notify you. Hope this message finds you well,
