  3. From Challenges to Solution: Interactive 3DX Canvas Session...
  • Replies 17
  • Views 2371
From Challenges to Solution: Interactive 3DX Canvas Session - Join us on July 22nd
Renu Vibha
Renu Vibha 4 months ago
Curious about how users are leveraging 3DX Canvas to accelerate PCB design and overcome complex design challenges?
Join us here, for an interactive live session with Cadence experts and get real-time answers to your most pressing PCB design questions.
Date: July 22, 2026
Time: 3:30 PM – 4:30 PM IST
What’s on the Agenda?
  • Model Mapper
  • 3D DRCs
Why Attend?
  • Get expert answers to your PCB design questions in real time
  • Discover practical, real-world use cases and best practices
  • Network with peers and exchange valuable insights and experiences
Bring your design challenges, explore innovative solutions, and leave with actionable insights you can apply immediately.
  • vidhyaparameswari
    vidhyaparameswari 3 months ago in reply to CF202606104231 +1
    The 3D DRC (Design Rule Check) feature in Allegro X PCB Editor is a validation tool that allows you to perform three-dimensional clearance checks and validate complex structures within a 3D environment…
  • vidhyaparameswari
    vidhyaparameswari 3 months ago in reply to EDAHut +1
    The system manages spatial collisions by checking 3D CAD models or component shapes which is Place Bound/DFA Bound against each other. We have Component to Rigid-Flex checks available which checks models…
  • EDAHut
    EDAHut 3 months ago
    Also, when utilizing Model Mapper to assign multi-pin IBIS or SPICE sub-circuit models to complex coupled differential pairs, how does Allegro resolve model-to-pin mapping discrepancies on non-standard, asymmetric pinouts? Is there an automated way to preserve coupling matrix data (S-parameters) across pin re-mappings without having to manually rebuild the signal hierarchy in SystemSI?
  • EDAHut
    EDAHut 3 months ago
    Is there a recommended best practice for integrating 3D DRC clearance rules directly into the Constraint Manager database so that dynamic shape updates trigger real-time 3D spatial checks without causing noticeable latency on complex 16+ layer boards with extensive mechanical STEP models?
  • vidhyaparameswari
     We have Component to Rigid-Flex checks available which checks models or shapes of a component against the outer surface of a rigid-flex.
    Dynamic Bends: The 3D DRC engine accounts for the bend state of the flex substrate. For example, if a flex portion is bent, the system measures the vertical distance from the component to the flex surface. If the clearance is insufficient, you can resolve the DRC by interactively changing the inner radius of the bend, which repositions the flex portion in 3D space
     For Thermal Expansion (CTE) and Deformation States, While the 3DX Canvas is highly effective at evaluating clearances in different deformation states (such as bent vs. flat flex substrates), the standard 3D DRC engine primarily focuses on geometric clearances based on the current physical state of the design.
    Deformation State: The system evaluates DRCs based on the specific bend parameters defined in the design. It does not natively simulate real-time material deformation or thermal expansion (CTE) within the 3D DRC check itself.
    Inter-Layer DRC: For rigid-flex designs, you can use Inter-Layer DRC to check for overlaps or spacing requirements between different material classes (like stiffeners and masks) that are critical for fabrication and assembly.
     For advanced thermal expansion or stress analysis, you would typically export the 3D representation of the design from the 3DX Canvas to a dedicated simulation tool.
  • EDAHut
    EDAHut 3 months ago in reply to vidhyaparameswari
    Since CTE and material deformation require dedicated external solvers, is there a streamlined or automated bi-directional workflow (such as via IPC-2581 or Celsius) to re-import calculated thermal deformation mesh data back into the 3DX Canvas so 3D DRC can be run against the actual deformed state?
  • techiecs
    techiecs 3 months ago in reply to EDAHut
    In Allegro X PCB Editor, the Signal Model Assignment tool (accessed via Analyze > Model Assignment) is the primary interface for mapping IBIS and SPICE models to components and their pins.
    While the Model Mapper being referred to here is the one which is used in 3DX Canvas that enhances the process of mapping 3D models to PCB components.
