  3. From Challenges to Solution: Interactive 3DX Canvas Session...
  • Replies 17
  • Views 2379
From Challenges to Solution: Interactive 3DX Canvas Session - Join us on July 22nd
Renu Vibha
Renu Vibha 4 months ago
Curious about how users are leveraging 3DX Canvas to accelerate PCB design and overcome complex design challenges?
Join us here, for an interactive live session with Cadence experts and get real-time answers to your most pressing PCB design questions.
Date: July 22, 2026
Time: 3:30 PM – 4:30 PM IST
What’s on the Agenda?
  • Model Mapper
  • 3D DRCs
Why Attend?
  • Get expert answers to your PCB design questions in real time
  • Discover practical, real-world use cases and best practices
  • Network with peers and exchange valuable insights and experiences
Bring your design challenges, explore innovative solutions, and leave with actionable insights you can apply immediately.
  • vidhyaparameswari
    vidhyaparameswari 3 months ago in reply to CF202606104231 +1
    The 3D DRC (Design Rule Check) feature in Allegro X PCB Editor is a validation tool that allows you to perform three-dimensional clearance checks and validate complex structures within a 3D environment…
  • vidhyaparameswari
    vidhyaparameswari 3 months ago in reply to EDAHut +1
    The system manages spatial collisions by checking 3D CAD models or component shapes which is Place Bound/DFA Bound against each other. We have Component to Rigid-Flex checks available which checks models…
  • vidhyaparameswari
    Integrating 3D DRC clearance rules directly into the Constraint Manager database is a best practice for achieving real-time spatial feedback in Allegro X PCB Editor, especially for complex 16+ layer boards with extensive mechanical STEP models.
    Constraint Manager Setup:
    You can specify 3D clearance values for horizontal and vertical spacing between components directly in the 3D domain of Constraint Manager.
    Navigate to Setup – Constraints – Constraint Manager.
    Under the 3D domain, expand the 3D Clearance folder.
    Create a new CSet (Constraint Set) and define the required clearance values for different component categories (e.g., mechanical, connector, discrete, BGA).
    DFA Device Classes: To optimize performance and reduce latency on complex boards, group symbol definitions that share the same clearance values using the DFA_DEV_CLASS property. This allows a single class entry in the spreadsheet to manage rules for multiple symbol instances (e.g., all 0805 packages), simplifying the database and accelerating real-time checks.
    Geometry Selection: When defining 3D spacing checks, you can select specific geometries to check, such as 3D CAD models (STEP) against other 3D models or board elements. By default, the system checks the 3D CAD model against the 3D CAD model if mapped.
  • techiecs
    techiecs 3 months ago in reply to EDAHut
    In Allegro X PCB Editor, while there may a tight integration with the Celsius Thermal Solver for thermal analysis, there is currently no automated, bi-directional workflow to re-import a calculated thermal deformation mesh data directly into the 3DX Canvas for automated 3D DRC.
    If an external solver (like Celsius or an MCAD tool) calculates a deformed state due to CTE or mechanical stress, that state can be exported as a STEP file.
    You can then try to re-import this "deformed" STEP model into Allegro as a mechanical component or enclosure. The 3D DRC engine in 3DX Canvas can then evaluate clearances between your PCB components and this deformed geometry.
    IDX Flow: For complex mechanical changes involving outlines, zones, and bends, the IDX flow is the recommended method for bi-directional data exchange between Allegro and mechanical tools.
  • EDAHut
    EDAHut 3 months ago in reply to techiecs
    Thank you … a follow up question is ….
    Since signal assignment relies on ⁠Analyze > Model Assignment⁠, how does Allegro manage automated pin-to-port mapping for high-pin-count, asymmetric S-parameter matrices or multi-gigabit differential pairs without manually assigning each net interface in Sigrity / SystemSI?
  • techiecs
    In Allegro X PCB Editor, automated pin-to-port mapping for high-pin-count and asymmetric devices is handled through the Signal Model Assignment interface and the Device Modeling Language (DML) framework.
    Additionally, Thank you for your question.
    I believe that this appears to be related to the Sigrity/SystemSI product area and would benefit from the expertise of the dedicated Sigrity team.
    I would recommend posting your question on the Cadence Sigrity Forum https://community.cadence.com/cadence_technology_forums/system-analysis/f/sigrity, where a domain expert will be able to review your query and provide the most accurate guidance.
  • vidhyaparameswari
    Thank You for Joining! Tada
    Thank you all for your active participation and engaging questions throughout this session.
    Although the live session has concluded, the forum will remain open. Please feel free to continue posting your questions, and we will be happy to respond and assist you.
    I appreciate your time and look forward to continuing the discussion!
