  3. mounting IC in 45deg
  • Subscribers 166
  • Views 670
Steik
Steik 3 months ago
Hi, I tried to mount a IC in 45 degrees, and that resulted in a landslide of pin to pin spacing DRC.
if I set the ic in 45deg iI get this error:
Constraint Type: NET SPACING CONSTRAINTS
  Constraint value: 0.2 MM
  Actual value:     0.1999 MM
 if I measure the Air Gap = 0.1999952 mm
if I set the IC to 90deg I get no errors, and Air gat measures to 0.2mm so a difference in 4,8nm
Can't Orcad do math?
Can this be fixed?
  • oldmouldy
    0 oldmouldy 3 months ago
    PCB Editor can do the maths but the square root of 2 is an irrational number so you cannot be presented with an "exact" number when processing it. Just relax the air-gap slightly to accommodate the calculation and remove the DRCs
  • HS202603175138
    0 HS202603175138 2 months ago
    The 45° rotation introduces coordinate rounding when Allegro snaps the pads to its database grid, so a nominal 0.2000 mm gap becomes 0.1999952 mm. The 4.8 nm differences is physically insignificant, but DRC applies a strict comparison. If 0.2 mm is only an internal rule, reduce it slowly or create a footprint-specific exception. If it is the fabricator’s minimum, adjust the pad geometry to provide real manufacturing margin rather than waiving the error.
