  3. NC Drill Holes Appear Offset from Gerber Artwork
  • Views 433
Electro Node
Electro Node 3 months ago
Hello Folks,
I have completed my PCB design and am at the stage of sending the manufacturing data to the fabricator. Before releasing the data, I wanted to verify the generated Gerber and NC Drill files myself.
While reviewing the outputs in a Gerber viewer, I noticed that the drill holes appear offset from the artwork data, which does not look correct. The board database itself seems fine, but the generated output files show a mismatch between the drill locations and the Gerber artwork.
What could be causing this offset, and how can it be corrected before sending the manufacturing package?
  • avant
    0 avant 3 months ago
    Make sure the board database and the NC parameters use the same units - metric or inches. Same with the Gerber viewer.
    Make sure there is no offset in the NC parameters.
  • Electro Node
    0 Electro Node 2 months ago in reply to avant
    Hi Avant,
    Thanks for the response. I was able to find it out in my case units were same but there was difference in the format 3:5 format.
    So this is resolved now. Thanks for the suggestion.
