  3. De assign netname for multiple pins at same time in all...
  • Views 665
De assign netname for multiple pins at same time in allegro
Sriranga
Sriranga 2 months ago
We can assign the netname to the multiple pins at a same time by using following option( file- import- logic) in PCB editor.
As like that I need to de-assign the multiple pins from different nets.Is there any default option?
For dense board if need to de assign the netname for multiple pins, currently i am deleting entire nets and then I import the netlist...this process give lot of reworks. If anyone have solution for this please give your guidance.
  • vidhyaparameswari
    vidhyaparameswari 2 months ago +2 verified
    Hi Sriranga, You can de-assign pins from their existing nets using the steps outlined below: Choose Logic → Net Logic from the top menu. In the Options tab, select the Deassign radio button.…
  • vidhyaparameswari
    +1 vidhyaparameswari 2 months ago
    Hi Sriranga,
    1. Choose Logic → Net Logic from the top menu.
    2. In the Options tab, select the Deassign radio button.
    3. (Optional) Enable Ripup Etch/Conductor if you want the connected traces to be removed automatically.
    4. In the Find filter, ensure Pins is selected.
    5. Click individual pins or drag a window to select multiple pins.
    6. The selected pins will be removed from their current nets and assigned to a dummy net.
    7. Right-click and select Done to complete the operation.
    If you later need to assign the pins back to a net, you can follow the same procedure and select the Assign option under Logic → Net Logic, then assign the desired net name to the selected pins.
    I hope this helps.
    • Vote Up +2 Vote Down
  • Sriranga
    0 Sriranga 2 months ago in reply to vidhyaparameswari
    Thanks, Vidhya.
    Using the Filter option, I was able to generate the .qfnd file. I then edited the QFND file and specified the pins from which I needed to deassign the net name.
    Based on the pins listed in the QFND file, I removed the net name only from the particular pins without removing the entire property associated with the net.
    I also received a script from my colleague to deassign the net name from the selected pins X & Y location.  The script is as follows:
    setwindow pcb
    ifp
    net logic
    setwindow form.find
    FORM find all_off
    FORM find pins YES
    setwindow form.mini
    FORM mini deassign YES
    setwindow pcb
    pick 11 12
    pick 12 13
    pick 13 14
    pick 14 15
    pick 15 16
    pick 16 17
    pick 17 18
    pick 18 19
    pick 19 20
    pick 20 21
    pick 21 22
    pop Done
    This approach allows us to deassign the net name from specific pins without affecting the other properties related to the net.
