  3. DFF Backdrill to Pad
  • Views 559
PCB6453
PCB6453 2 months ago
Hello All,
I'm setting up my DFF constraints for backdrills on vias.  The value that I have for Backdrill to antipad is 10 mils.  I'm unsure of what value I need to put in for Backdrill to pad if I want the whole pad removed.
Thanks!
  • JuanCR
    0 JuanCR 2 months ago
    Hi! Are you intending to configure these values so that it sets up your backdrill? The way to set up the backdrill is actually in Manufacture > NC > Backdrill Setup
  • PCB6453
    0 PCB6453 2 months ago in reply to JuanCR
    No really.  I'm trying to make sure that the clearance from the edge of my backdrill is far enough from the pad that it will delete the whole pad entirely.  So, I saw this on the DFF section and I was thinking that this is where I have to put in the rule.
