  3. Differential pair pad entry
  • State Suggested Answer
  • Answers 4
  • Views 449
YJ202407185547
YJ202407185547 26 days ago
The differential pair entry into a pad in allegro 23.1 was ortogonal
However, Since I uploaded allegro 25.1 the differential pair entry is different and I'm not able to route it orthogonal to the pad:
Does anyone know how to change the entry?
Thank you in advance.
  • excellon1
    0 excellon1 1 day ago in reply to steve
    There are many moving parts to the Diff- Pairs, One thing worth trying is the miter factor. If this is too low then your etch may not escape the pin and turn to sharply.
    So click on your pin to start your diff pair. In the "Options Pane" check to see if the actual miter is at a minimum 2xwidth. You can change that to a higher value to see how the diff-pair responds. If the Miter is set to something like 1xwidth the etch will turn too sharply and not escape the pins as you want.
    Its  also possible to use single trace mode. In that mode you route off the pin a certain distance then  left click to stop routing, next right click and uncheck single trace mode. The other pin should route in to match the etch you started.
    So click on pin both diff-pairs appear. Right click and choose "Single Trace mode" Rote off the pin and left click to stop routing. Right click and uncheck "Single Trace mode"
    Let us know if it works.
    More than likely the trouble is related to the miter. A good value for Pad Entry Factor is 75 !
