  3. how can i take value of component (or symbol) through skill...
  • Views 15821
how can i take value of component (or symbol) through skill?
archive over 21 years ago
hi ,
help me ,
thanks
Originally posted in cdnusers.org by microhelp
    cadr(assoc('VALUE, axlDBGetProperties(comp ->compdef)))
    Originally posted in cdnusers.org by nzdave
    thanks
    haojingchao.chinese
  • andakConsultingLtd
    andakConsultingLtd over 1 year ago
    Hello there,
    First of all make sure you pass the value from OrCAD Capture to PCB by enabling it in allegro.cfg file:
    Thus, under [ComponentDefinitionProps] section, make sure VALUE=YES
    The following SKILL code should help you get started with your task, you can run them line by line in your SKILL command line:
    axlSetFindFilter(?enabled `("NOALL" "COMPONENTS") ?onButtons `("COMPONENTS"))
    axlSelect(?prompt "Select component by pick.")
    compID = car( axlGetSelSet())
    componentValue = compID->compdef->prop->VALUE
