  3. how to get component (or symbol) 's center
  • Subscribers 163
  • Views 11285
archive over 21 years ago
hi,all
how to get component (or symbol) 's center coordinate?
thanks
haojingchao .chinese
Originally posted in cdnusers.org by microhelp
    Hello MicroHelp,
    ;obtain component dbid
    axlSetFindFilter( ?enabled list("noall" "components") ?onButtons list("components") )
    axlSelect( ?groupMode nil ?prompt "Please Select Component" )
    ;user clicks component
    component_dbid = axlGetSelSet()
    ;now use bBox to find center
    component_bBox = component_dbid->bBox
    ; ( (LowerLeft_X,LowerLeft_Y) (UpperRight_X,UpperRight_Y)
    ; now just write code to obtain center
    Also possible is
    component_position = component_dbid->xy
    however I'm not sure if this will get the 'center' of component
    regards,
    Newbie
    Originally posted in cdnusers.org by Newbie
    thanks very much,
    let me test;
    microhelp .chinese
    Hi All,
    Attached is a skill file that draws the bBox of a symbol on the BOARD GEOMETRY/OUTLINE layer.
    to use it
    1. Place ShowbBox.il in your skill directory
    2. Type "skill" on command prompt
    Command> skill
    3. Type " load "ShowbBox.il" "
    Skill> load "ShowbBox.il"
    4. Type "exit"
    Skill> exit
    5. Type "ShowbBox" and click on symbol you want to display the bBox
    Command> ShowbBox
    What i noticed is that sometimes the bBox rectangle isnt 'centered' on the symbol.
    Does anyone know why this is so?
    this will also mean that we cant really use the bBox of symbol to find center of component... sorry microhelp
    I know that using "location" doesnt work as it will be the "origin" of the component when it was created by the librarian.
    Does anyone have a better suggestion as to how to find the center of a component?
    thanks
    newbie
    ShowbBox.zip
    correct file
    please use this
    ShowbBox.zip
    This solution won't work if symbol objects are outside the Assembly outline. A better solution would be to take all the Assembly outline objects of the symbol and find the centre of those.
    Originally posted in cdnusers.org by nzdave
