  3. How to generate a BOM report using SKILL
  • Subscribers 163
  • Views 16119
archive over 21 years ago
Is there anyone who can tell me the major steps and "cn" functions to generate a complete BOM report using the Allegro Design Entry HDL SKILL for a given schematic design?
Thanks.
lipeijia@usg.com
Originally posted in cdnusers.org by pjli
    pjli,
    Response from Cadence engineering:
    Creating a BOM from SKILL is touchy since the script then needs to do the work of packager-XK before running BOM.
    Much better to use Caeviews ( and all details are in the Caeviews user guide )
    Moderator
    Originally posted in cdnusers.org by Moderator
    Moderator,
    Thanks for your help. I just tested an indirect way to generate a BOM by using command "bomhdl" in the -nographic option. Basically, I created a BOM template file separately to define the properties to be report first. Then invoke the command bomhdl with required parameters such as project name, template file name, and output file name. After being created, the output file is read back and parsed to generate a new BOM file with the desired format. The invocation, reading, and parsing can be done by SKILL programs. It seems working fine. I believe that CAE Views HDL programming will be more powerful, flexible, and having performance. I will possibly look into it if my tested approach cannot meet requirements.
    Thanks.
    lipeijia@ugs.com
