  3. POWER_GROUP vs. POWER_PINS
  • Subscribers 163
  • Views 14581
archive over 21 years ago
Similar to the "Assign Power Pins" gui that allows you to redefine the POWER_PINS, has anyone created a skill routine that does the same but for POWER_GROUP instead?
On large parts, such as FPGA's where there are many power pins, having a POWER_PINS property is unwieldy if you happen to have it displayed. Further, the way the gui works you could actually tie the wrong powers together if you weren't careful selecting. A more efficient method to re-assign the power pins is with the POWER_GROUP property. A gui similar to the assign power pins function would be helpful. Also, the property value is small enough it could be displayed.
Originally posted in cdnusers.org by nolan.watts.iii
    You need to create a property template in cnskill and attach the property to the component. There should be such a function in the stdAccess.il file (global change uses it). just search the install dir for it.
    If this doesn't help let me know. I have such a function somewhere!
    Andy
    Originally posted in cdnusers.org by andyk
