  3. How to Create a Partial-Depth Cavity in Only One Substrate...
  • State Suggested Answer
  • Answers 1
  • Views 137
How to Create a Partial-Depth Cavity in Only One Substrate Layer in Allegro PCB Editor 25.1?
OS202611127246
OS202611127246 5 days ago
I am designing a structure consisting of two stacked RO4530B substrate layers in Cadence Allegro PCB Editor 25.1.
I want to create rectangular and circle cavities in the upper RO4530B layer only, while keeping the lower layer intact.
However, using Board Geometry → Cutout removes material from both layers.
Is there a way to create a partial-depth cavity in only the upper substrate layer and visualize it correctly in Allegro's 3D view?
If this is not directly supported, what workflow would you recommend?
  • excellon1
    0 excellon1 2 days ago
    HI DS2026
    Couple of notes: The Board Geometry Cutout Class does indeed remove material graphically on your screen, however there is no  NC Milling paths associated with this which means you wont be able to supply routing info for the cutout to your fabricator.
    Use Board Geometry Ncroute_Path to make the cutout instead. When creating NC route files during post process a *.rou file will be created. This file is the Cam file that is used by the NC-Routing equipment at the board house. On your fab drawing you should indicate how deep you wish the routing to be. You will need to specify that.
    When you view the NCRoute_Path in the 3d viewer it will show the cutout right through the board. This is because the NCROUTE_PATH is unaware of how deep the cut should be. Its just visual only and is based on the total board thickness.
    From a visual perspective it is possible to show the slot a different depth, This can be done by faking things out so it visually looks the way you want. For this you could use the package geometry - place bound top layer. This particular layer used to be used so as to show a visual representation of the component prior to the use of step models in allegro. Its also used for package to package spacing. Basically draw a shape on that layer and then set its properties for package height min and max. On something like a 62mil board you could use properties of Height max -50 & Height min -60. etc.
    Its not really necessary to fool the 3D viewer but hey it can be done ! :)
    If you want to try things out, just create a Mechanical Footprint using any shapes you want based on the the classes mentioned above and save it. In the pcb editor you can place the symbol and adjust its size to fit if needed since they are only shapes.
    The above will work with all versions of Allegro from 17.2 on, If im not mistaken I believe Allegro has a package designer product that my handle this better.
