  3. Net Names Not Visible on Traces and Pads
  • Views 113
Siri
Siri 4 days ago
In PCB Editor net names are not visible on traces and pads.
Could you please let us know what might be causing this issue and suggest the necessary settings or steps to make the net names visible?
Thank you
  • mahimag
    0 mahimag 10 hours ago
    Hi Siri , make sure the opengl/gpu is not disabled.
    Once you have the graphic support, uou can enable them from Setup > Design Parameters abd enable them in "Display Embedded names" section or "Display Net Names" if you are on older release. You can also check the transparency in Color Dialog box > display pane to make sure it is not 100% opaque.
  • avant
    0 avant 10 hours ago
    Setup/Design Parameters
    Check the "Display net names" boxes
