  3. What are your biggest packaging problems?
  • Subscribers 163
  • Views 78
John T
John T 4 days ago
PCB packaging has changed drastically in the last decade. Shrinking package sizes sometimes offer less attractive options as we advance. Shrinkage however, is key to cost reduction which is tantamount to product success. But when should we begin to do something completely different in our PCB designs to overcome these challenges?
So, what are your biggest package challenges currently in Design?
  1. Pin escape: Trying to keep pcb layer count low but is difficult to trace escape from tight packages.
  2. Solder-bridging: Very fine scale packages leading to solder issues.
  3. Old technology still used to assemble specific parts. Example, connectors and solder wave.
  4. Mismatch of component assembly types. Example, glue dots or component size mismatches leading to difficulties in placement impacting ideal routing.
  5. Inspection costs: Components such as special uBGA, DFN or Power flat packs requiring Xray inspection or other verification processes.
  6. Enclosures, shieldings or matings. Interacting small pcbs with real world geometries.
  7. Warpage and thin substrates: How does your pcb, substrate or flex board interfere with the pcb layout and component reliability.
  8. Micro-Solder Joint Reliability and Solder Voids: Achieving quality product can be difficult when not much solder is applied.
  9. Using wirebond for chip-on-board (COB)...
Do consider any of the above answers or else educate our community with your special insights or alternative views. Looking forward to hearing from you!
 Die to BGA
