  3. PCB Layout Techniques for High-Power Applications
  • State
  • Views 4
Renu Vibha
Renu Vibha 18 minutes ago
600 A through one square of 1 oz copper drops about 0.3 V and burns about 180 W.
That’s the starting point for any board above 600 A, and it gets worse. Copper resistance climbs about 0.4% per °C, so a section that heats up drops more voltage, which makes more heat. Checking voltage drop at 25°C tells you very little about the hot board.
Point right https://ow.ly/vpzu5100BrO
Above 150 V, insulation becomes its own layout problem. Clearance is the shortest path through air. Creepage is the shortest path along a surface. They are two separate checks, set by working voltage, pollution degree, and material.
Then there’s everything in the current path that isn’t a trace. Every via, solder joint, and connector adds resistance and a local hot spot, and each one has to survive thermal cycling for the life of the product.
John Carney covers current paths, voltage drop, heat, creepage and clearance, interconnect reliability, and manufacturability for boards beyond 150 V and 600 A. The recording is now on demand.
#PCBDesign #Webinar
