  3. How can I visualize actual impedance variation along a complete...
  • Views 5
How can I visualize actual impedance variation along a complete routed net in Allegro PCB Editor?
Electro Node
Electro Node 38 minutes ago
Hi All,
I am looking for a way to visualize the actual impedance along the entire routed length of a net in Allegro PCB Editor. For example, if a 50 Ω trace has neck-down sections, width changes, reference plane discontinuities, or layer transitions, can Allegro show where the impedance changes and by how much along different segments of the trace?
I am specifically interested in identifying impedance discontinuities caused by the actual routed geometry and reference structure, rather than just checking the defined target impedance.
Is this possible directly in Allegro PCB Editor, or is an additional SI analysis tool/license required?
 Thanks!
