  3. MiniStatus Forms
  • Subscribers 163
  • Views 15452
MiniStatus Forms
archive over 20 years ago
I am developing utilities using MiniStatus forms. I have to retart Allegro, every time I make a change to the form, to see those changes. Is anybody aware of a way around this?
Cheers, Dave
Originally posted in cdnusers.org by Dave Elder
    For development, I change the form file name after every change.
    file1.form
    file2.form
    file3.form
    Once all is good, I rename to what it should be and restart Allegro.
    If you need to test the layout (no functionality)of forms that you are creating dynamically, I suggest using the axlFormTest procedure to test the forms.
    Originally posted in cdnusers.org by natebizu
    Good work around, thanks!
    Dave,
    Another method that would work would be to get the date/time and use that to construct the filename. That would insure uniqueness. Once you get what you need, delete all but the most recent form.
    OR
    Create a global variable when you launch Allegro and everytime you reload the .il file, have it automatically increment the variable. Then use the variable to construct the form filename.
    Just a couple of other ideas.
    Originally posted in cdnusers.org by cdavies
