  3. Problem about teh strcat command
  • Subscribers 163
  • Views 17400
archive over 20 years ago
I'm a newcomer, and I'm studying the SKILL.
I wrote some code to report the dummy net pin and single pin( or unconnected pin), then asign the list to a form, browse them one by one. But one problem occured. For some projects, there is a error information for strcat command:
Error* strcat: argument #1 should be either a string or a symbol
The part of code is like this:
let((Pin_List Dummy_Pin_List Single_Pin_List)
Pin_List=Dummy_Pin_List=Single_Pin_List=nil
foreach( item Pin_List
if(item->net->name=="" then
Dummy_Pin_List=cons(strcat(item->component->name "." item->number) Dummy_Pin_List)
Dummy_Pin_List=sort(Dummy_Pin_List 'alphalessp)
else
if(length(item->branch->children)==1 then
Single_Pin_List=cons(strcat(item->component->name "." item->number " / " item->net->name) Single_Pin_List)
Single_Pin_List=sort(Single_Pin_List 'alphalessp)
);if
);if
);foreach
);let
Who can help me with this problem. thanks.
Originally posted in cdnusers.org by leonlee
    of course
    The Pin_List is generateed by below code:
    axlDBRefreshId(axlDBGetDesign())
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall pins) ?onButtons '(noall pins))
    Pin_List=axlGetSelSet(axlAddSelectAll())
    You are getting every pin record in the board database. Some of theins may be mechanical pins which have no number value. Then when you strcat item -> number strcat fails as you are seeing.
    Try adding a conditional that traps null item -> numbers
    For example
    if(item -> number != nil then
    Originally posted in cdnusers.org by AshCan
    OK, thank you very much for your answer.
    I'll try it soon~~~
    Another technique to address unwanted nil values is to use OR:
    strcat(x y item->number||"" z)
    Since 'or' stop evaluating on non-nil ("true") values from left to right.
    And not related to your question - you should sort once after
    the foreach statement (for improved performance).
    Originally posted in cdnusers.org by natan
    Ok, the reason is:
    for the mechanical pin, item->component=nil item->nuber=""(null)
    I ignored it~~~
