  3. Override or hook read-only function - how?
  • Subscribers 163
  • Views 4019
archive over 20 years ago
This is more in the nature of a general Skill question, but this topic seems to be the most active, so forgive the intrusion.
Does anyone know if there's a means to hook or override native code function objects? For example, if I wanted to log all invocations of the various ipc* functions it would be handy to be able to place a routine of my own in the control flow, grab and log the args and then pass control to the "real" ipc routine.
All the ipc* functions show up as being read-only and any attempt at assigning a new function to the symbol results in an error.
Any input or insight will be appreciated.
Steve
Originally posted in cdnusers.org by shirsch
    Here is an example that may be useful.
    The ipc356_out command is called when you select File -> Export -> IPC356 from the main Allegro menu. You want to do something a little different then the generic ipc356_out function.
    First you would need to build the function you do wish to execute (some special extracta routines or specialized database reads, perhaps using a customized form UI). Let's say that you call this compiled Skill function "my_IPC_out".
    You can use the axlCmdRegister utility to "create" a user-defined Allegro command or, in this case, you would use this utility to redefine the existing Allegro command.
    axlCmdRegister("ipc356_out" 'my_IPC_out)
    Now when you enter ipc356_out from the Allegro command line the compiled function "my_IPC_out is executed. If you want to call the custom function from the Allegro menu you could ....
    axlCmdRegister("ipc356_private" 'my_IPC_out)
    and then modify your Allegro menu from ....
    MENUITEM "IP&C 356...", "ipc356 out"
    to ....
    MENUITEM "IP&C 356...", "ipc356_private"
    Originally posted in cdnusers.org by AshCan
    Or you could just use:
    axlCmdRegister("ipc356 out" 'my_IPC_out)
    and make no Allegro menu changes.
    I think the function you are after is clearFnWriteProtect
    However, this will not work with system functions, such as ipcBeginProcess. I doubt that you can (or would want to) hijack these commands directly.
    Originally posted in cdnusers.org by Dave Elder
