  3. Remove repeat item from a list
  • Subscribers 163
  • Views 18162
archive over 20 years ago
I have tried some way to remove some repeat item from a list.
Followed is the simple one
foreach(item list
list=cons(item remove(item list))
Do anyone have a more available command or fuction?
Originally posted in cdnusers.org by leonlee
    This is what I use...
    procedure(_removeDuplicates(masterList)
    let((finalList)
    foreach(item masterList
    unless(member(item car(finalList))
    finalList=tconc(finalList item)
    finalList
    If your are going through a list of dbids, then you can use memq instead of member to speed this up.
    Originally posted in cdnusers.org by natebizu
    I use "makeTable" because it doesn't accept duplicates.
    below is code from a program I wrote called highlight_padstacks.il that is in the downloadable user skill zip file from cadence. I make a list by selecting all pins and via, and then load the names into a table.
    padstacklist=makeTable("atable1" 0)
    axlSetFindFilter(?enabled list("noall" "pins" "vias")
             ?onButtons list("noall" "pins" "vias"))
    axlAddSelectAll()
    pin_list = axlGetSelSet()
    foreach(pin_db pin_list
      padstack_db = pin_db->definition     ;Extract PadstackID from pinID
      pad_name=padstack_db->name      ;Extract Padstack Name from PadstackID
      padstacklist[pad_name]=pad_name  ;Load into table as Name:Value
    );end foreach
    Originally posted in cdnusers.org by Geoffm
    archive over 19 years ago
    Now I use below code to this solution:
    procedure( RemoveDuplicateItem(A)
    B=nil
    while(A!=nil B=cons(nth(0 A) B) A=remove(nth(0 A) A))
    B
    );procedure
    You could try using the unique function
    For example, this will weed out all duplicate via names from a list:
    via_name_list = unique(sort( via_name_list 'alphalessp))
    A more-generic-but-trickier method involves using a foreach loop and the member funtion.
    Someting like:
    ulist = nil
    foreach( obj obj_list
    unless( member( obj ulist)
    ulist = cons( obj ulist)
    );end-unless
    );end-foreach
    HTH,
    Chris Walters
    local Cadence guru
    PS - anyone know of a position for a(nother) Cadence guru?
    Originally posted in cdnusers.org by kerchunk
    It's wonderful for the unique function. which user guide offers these functions?
    I don't know the Cadence guru position. where~~
