  3. About the axlGetParam command
  • Subscribers 163
  • Views 15246
archive over 20 years ago
I want to get the TextBlock attribute by variate.
1. The general situation: OK
p=axlGetParam("paramTextBlock:2")
 p->??
(objType "paramTextBlock" width 0.584 photoWidth
    0.127 name "2" lineSpace 0.991
    height 0.787 charSpace 0.203
2.
n=2
p=axlGetParam("paramTextBlock:n")
p->??
=>(objType "paramTextBlock")
3.
procedure( Text(x "n")
axlGetParam("paramTextBlock:x")
Text(2)->??
The result of the 2nd and 3rd situation are not correct. why? how can I get it?
Originally posted in cdnusers.org by leonlee
    The problem is that you are passing a string to the axlGetParam procedure.
    Because "x" is inside of double quotes,  you are passing a string "x" rather than the evaluation of the variable x.
    use sprintf, and I would check to make sure that x is an integer:
    procedure(Text(x)
       when(integerp(x)
          axlGetParam(sprintf(nil "paramTextBlock:%d" x))
    This should return the param or nil (when invalid input).
    Originally posted in cdnusers.org by natebizu
    Ok.
    It means that I can use sprintf to convert  number type to string type.
    haha, thanks.
