  3. Wire keepout over via skill program
  • Subscribers 163
  • Views 18162
archive over 20 years ago
I am looking for skills program which create wire keepout shape on via.  Anyone has such program to share with me?
Thanks in advance.
Stella
Originally posted in cdnusers.org by ystella
    Hi Stella,
    Nice to hear from you.
    This is not a difficult task - try using the axlPolyFromDB command.
    eg. poly = car(axlPolyFromDB(via_dbid ?layer "ETCH/TOP" ?padType "REGULAR"))
    You can then create a keepout shape on the appropriate layer using axlDBCreateShape:
    axlDBCreateShape(poly, t, layer)
    I hope this helps.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    Nice to hear from you and glad that you are moderating this forum.  Guess I have a lot to learn from you.
    I left out a some detail.  I am looking for slightly more ie the wire keepout to be created will exclude any cline connect to the via.    In the attached.  Thanks for the code, it is a good starting point.
    Stella
    Hi Stella,
    Have a look at the attached code. I hope it helps.
    It makes use of the axlPoly commands which are great for doing this type of task.
    Cheers, Dave
    stella.il
    Hi Dave,
    Thanks for the great help.  I did a little customisation and now I am using it for my design.
    Have a nice weekend.
    Stella
    Dave,
    Stella is working at the board level, in particular, the vias on the board level.
    Can you give me your reasoning for putting the new "WIRE_KEEPOUT" subclass within the "PACKAGE GEOMETRY" class?
    thanks,
    jcr
    Originally posted in cdnusers.org by J.C. Roberts
