  3. Skill code to move component
  • Replies 34
  • Subscribers 167
  • Views 40571
archive over 20 years ago
I'm trying to generate a skill program that launches place manual -hide and then picks a specific coordinate to pick up the component placed in that coordinate.
I know that I have a pin placed in 0,0 and would like the skill program to pick that coordinate and leave the component on the mouse for me to place manually.
I've tried doing the following
axlShell("place manual -h")
axlShell("pick 0 0")
and I've also tried running a script that I've recorded that does the exact same, but both methods fail. They do launch the place manual command but I cannot get skill to pick that coordinate so that it is left for me to move the component
Does anyone have some good ideas, thanks.
Best regards,
Ole
Originally posted in cdnusers.org by ejlersen
    Hi Ole,
    Took me a while to figure that one out!
    Here's some improved code. Please let me know if it is actually better.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    moveByRefdes.il
    Hi Dave,
    This seems to work, so thanks a lot for this Dave.
    Ole
    Hi Dave,
    Do you know if it there exist a command to add the ratsnests to the components during a move command?
    Best regards,
    Ole
    Hi Ole,
    It is possible but my attached code uses some more private functions.
    Cheers, Dave
    moveByRefdes.il
  • satya12
    satya12 over 17 years ago
    Could you attach zip format file.
