  3. Skill code to move component
  • Replies 34
  • Subscribers 167
  • Views 40576
archive over 20 years ago
I'm trying to generate a skill program that launches place manual -hide and then picks a specific coordinate to pick up the component placed in that coordinate.
I know that I have a pin placed in 0,0 and would like the skill program to pick that coordinate and leave the component on the mouse for me to place manually.
I've tried doing the following
axlShell("place manual -h")
axlShell("pick 0 0")
and I've also tried running a script that I've recorded that does the exact same, but both methods fail. They do launch the place manual command but I cannot get skill to pick that coordinate so that it is left for me to move the component
Does anyone have some good ideas, thanks.
Best regards,
Ole
Originally posted in cdnusers.org by ejlersen
  • rahays
    rahays over 16 years ago
    Dave,
    When I try to use the moveByRefDes.il program I get the following error in Allegro:
    E- *Error* moveByRefdes: too few arguments (1 expected, 0 given) - nil
     What does that mean? Do you have a latest .il program? I am trying to move by coordinates, rotation, mirror within one screen.
     Bob Hays
  • rahays
    Dave,
     Bob Hays
    bob.hays@coachcomm.com
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Bob,
    Type "moveByRefdes [refdes]" on the command line. Where [refdes] is the symbol you want to move.
    eg
    moveByRefdes IC101
    Newer code is attached.
    Cheers,
    Dave
    moveByRefdes.zip
  • rahays
    Thanks, Dave - that does work. I had it as a custom menu item which gave me the error when I tried to activate the code from the menu.
    What I am looking for is the ability to move any component by coordinates, rotation, and mirror/not mirrored, kind of like a properties info window. I have many components to move from a list of location coordinates.
    Do you know where I can find code like that? I have looked without success.
     Bob Hays
    PCB layout engineer
    Coachcomm, LLC
    Auburn, AL 36830
    PCB
  • DE202408202727
    Hi Bob,
    I'm not aware of any specific code to do that. The closest code I have is my tool to import an IDF interface from Pro-Engineer. (The Cadence interface isn't yet good enough for our purposes).
    This requirement is fairly standard Skill stuff. It should be relatively easy to write code to read a file containing a list of parts and their new locations and move them accordingly. You could adapt the moveByRefdes code quite easily.
    Dave
