  3. Moving an object with axlTransformObject
  • Subscribers 163
  • Views 16954
archive over 20 years ago
I am having trouble getting data into the axlTransformObject command.
I am using concat to join the x value, a comma, and the y value, and then insert the result into the transform object line, but it's separating the first number with \'s. I guess this means there is something I don't know about concat.
when i run the program printf prints:
compLoc (9865.0 8195.0)  2135  1805
Concat \2\1\3\5\,1805
W- *WARNING* (axlTransformObject): ?move option requires a delta x/y location
here is an example from the Cadence skill guide:
   axlTransformObject(ldbid, ?move '(100.0, 0.0))
see my code below...
(defun MoveIt ()
   Plist=axlGetSelSet()
   axlShell("Done")
  ;pick new location
  newlocationX=12000
  newlocationY=10000
  ;printf("Plist  %L \n" Plist)
  (foreach comp Plist
      ;printf("compLoc %L " comp->xy)
      deltaX=round(newlocationX)-round(car(comp->xy))
      deltaY=round(newlocationY)-round(car(cdr(comp->xy)))
      printf(" %n  %n \n" deltaX deltaY)
      deltaXY=concat(deltaX "," deltaY)
      printf("Concat %L \n" deltaXY)
      axlTransformObject(comp, ?move 'deltaXY)
  );end for
hope somebody can help!
Originally posted in cdnusers.org by Geoffm
    The move option expects a list of two floating point arguments not a string.
    A string is produced by strcat. Also I don't think you want to round your coordinate
    calculation.
    The following should do it:
     deltaX = newlocationX - car(comp->xy)
     deltaY =  newlocationY - car(cdr(comp->xy))
     axlTransformObject(comp ?move list(deltaX deltaY))
    Originally posted in cdnusers.org by fxf
    Your solution worked, fxf!
    I guess you don't need the comma between x and y values as in the cadence example.  Also, you used "list" instead of '. That was the only thing I didn't try.
    Thanks again.
    Commas are optional and allow for a "C" programming style
    The difference between list and quote (') is that lists causes evaluation while
    the quote doesn't. To show this with a simpe example.
    Assuming:
        dx=10
        dy=20
    Do the following :
          xy = list (dx dy)
    result: xy = (10 20)
    While
          xy = '(dx dy)
    result: xy = (dx dy)
    You can also use the shorthand colon notation in place of list for 2 elements so
          xy=dx:dy
    I was always a bit hazy about, the difference between ' and List. Thanks for the input.
